Need some info on bulbs in the car
Old Mar 24, 2014 | 07:10 PM
Mikecsti's Avatar
Default Need some info on bulbs in the car
Guys 1998 accord ex v6, the clock light bulb, and the bulbs for the digital heating and ac controls. I'm looking on rockauto but there so many bulbs on here witch once are the right once? are they {#BP158} Miniature Lamp or {#35505S84N01} I believe this is the clock bulb. {#79672S84A41} it says is for the heater. The digital is not lit up at night but it still tells you the temp and so on. the fan control dose not light nor do some of the buttons. I do not need to go led here. this is my wife's car, that she's b*** she can't see anything at night, plus the bulb for half the tach just went out, not that she needs that. Let me know, so I can get them and install them.
thanks
Old Mar 25, 2014 | 11:23 PM
I am not sure about the radio. It could be the bulbs or possibly the radio itself.
Here is the clock backlight:
Cluster, but not sure this is the correct bulb for your problem. The fix would be similar. You may want to disconnect the three harnesses from the cluster and check all the bulbs:
Old Mar 27, 2014 | 08:34 AM
Mikecsti's Avatar
Thanks for those.
I'm looking on
and I need all those bulbs but thers is no bulb for the display? Can I change it?
Old Mar 28, 2014 | 03:43 PM
For the clock and cluster, I can understand one bulb going out. The clock is common and the cluster is less common for burned out bulbs.
Having all the radio bulbs burn out (at once?), would lead me to a possible problem with the radio itself. Maybe inspect the circuit board for burned resistors, leaking capacitors, etc...
trvcampbe
Aug 31, 2010 08:08 AM
jbrams
May 11, 2010 10:30 AM
asm2244
Jul 24, 2009 08:31 PM
accordingly01
Mar 4, 2008 11:54 AM
mwr
Aug 30, 2006 12:57 AM
