New 93 Accord owner with some questions...
Old Mar 5, 2008 | 08:01 PM
t12355
Default New 93 Accord owner with some questions...
I was happy to find such a place to contact other honda owners and get advice on how to take care of my new/old car! This is great!
Anyway, I recently purchased a 1993 Honda Accord 10 Annv Ed. It only has 103K and I will be the 3rd owner. The orig owner told the person who I bought it from that the timing belt HAD been changed at about 91K. I had it inspected before I bought it and it needed to have some things done like a cam shaft seal replaced, a crank shaft seal replaced. But when the engine was opened up it was verified that the timing best was OK, no oil had saturated it. Whew! Also, the CV joints needed greasing.
My question is, is there any advice on how to maintain and take care of this 15-16 year old car? High mileage oil? Anything flushed? I do notice that when I put it in park, reverse or drive that it "shakes" really hard. Is that normal?
Any advice would be very helpful. This is going to be a commuter car that needs to last as long as it can. We know what they say about Hondas, but I really want to take good care of this car.
Thanks for any help and advice!
Old Mar 6, 2008 | 12:48 AM
Slusher's Avatar
Default RE: New 93 Accord owner with some questions...
I would look over you engine/tranny mounts and look for worn bushings. If they did that engine stuff coolant should be good. Tranny Fluid?
Old Mar 6, 2008 | 03:04 PM
MikeT's Avatar
Not sayint it is normal, but my '93 has done that since I got it with about 50K on it. I always thought the idle was a little low...... It doesn't really bother me.
Old Mar 6, 2008 | 06:15 PM
hondadude's Avatar
If they are going into there to replace the crank seal anyway, get the oil pump seal replaced. That is probably what is really leaking and not the crank seal.
For your idle concerns, clean out the throttle plate area, probably a ring of sludge around the plate,and take the air Idle control valve off, it has a screen on it that will be plugged up with crud.
Inspect the front subframe "dogbone" motor mount, the top bushing usually goes bad.
Throttle plate cleaning;
[IMG]local://upfiles/5417/503E72D6E0804291A140D9FC4570D841.jpg[/IMG]
Old Mar 7, 2008 | 08:45 AM
t12355
Hey guys, thanks a lot! This place is really helpful.
Have a great day!
tony
Old Mar 7, 2008 | 10:36 AM
MikeT's Avatar
ORIGINAL: hondadude
Where is that located? I figure I can take off the rubber hose going onto the throttle body and get a good look at the throttle plate area to clean it but I am not sure where the idle control valve is.
I have replaced the FITV (fast idle control valve) but I think that is different from what you are talking about.
Old Mar 7, 2008 | 11:57 AM
Fast-idle valve is #8.
AICV is #15.
Old Mar 7, 2008 | 10:02 PM
MikeT's Avatar
So is the Idle control valve and the AICV the same thing?
Old Mar 7, 2008 | 10:09 PM
ORIGINAL: MikeT
Yes, sorry. Idle-Air Control Valve soI should havesaid IACV.
(Saab used to call their similar valve AICV for Adaptive Idle Control Valve...)
D-ODD-1
Aug 22, 2011 09:24 PM
ShadowWolf9
Apr 19, 2011 12:19 AM
kemullen73
Mar 26, 2011 08:31 PM
kmd1776
May 29, 2008 07:24 PM
DDRaptor
Apr 27, 2006 11:55 PM
