new guy here w/ Auto Trans Problem
Old Jun 10, 2011 | 12:23 PM
bec's Avatar
bec
Default new guy here w/ Auto Trans Problem
hi everyone:
i'm brand new here. i'm grateful i found this site. i need help with my car.
i am in my 40s and disabled. money is tight. therefore, i try to work on my car myself.
i own a 1991 accord DX sedan with a 2.2 liter engine and an automatic transmission. i am having a problem with the shifting of the transmission and another with the fast idle. i wonder if the two are related.
i use public computers and my time on them is limited. so, i'll give a full explanation of my car problems as soon as i can.
my accord has only 130,000 miles on it. it had 52,000 miles when i bought it. due to my disability i only drive about 7-8000 miles/year. it's my only car.
i bought it back in the winter of '98 and it has ran well thus far. this transmission problem is the only major trouble it's given me.
that's all for now folks. thanks for reading this.
bec
Old Jun 10, 2011 | 05:51 PM
Moved your post for more exposure.
Is the Check Engine Light on? Even if not, suggest checking for trans code by shorting the service check connector under the glove box w/ a paper clip and reading the codes. Check DIY forum for help w/ obtaining codes.
Post your TCU codes and someone can help.
Old Jun 10, 2011 | 08:39 PM
piggylover1985's Avatar
High idle could cause automatic transmission to have harsh engagement, could have late/harsh shifting problem. You didn't said what kind of problem with the transmission either. So it will be hard for us to diagnose the problem.
Old Jun 11, 2011 | 09:00 AM
EXV6NIGHTHAWK's Avatar
Is the D4 light on, when it shouldn't be? If the light stays on constantly (not blinking), you could have a bad computer. The computers can be repaired, sometimes. A new computer is pretty expensive. If you take the cover off the computer, and find black spots on the curcuit board, you've found the problem.
Old Jun 11, 2011 | 10:59 AM
Used computers are available at very reasonable prices $25-$50.
Old Jun 11, 2011 | 11:12 AM
Let's slow down just a bit. The op needs to come back and give a little more information....without any codes (op please check for these, in the DIY section there is a "how to"), then lets start with a fluid change, or two, or three if we are not sure when it was last done. Then check the throttle control cable for proper adjustment.
Old Jun 13, 2011 | 12:38 PM
bec's Avatar
bec
hi guys:
thanks for your help. i posted a detailed description of my car problem in the
General Tech Help forum section of this site. please read it there. bye,
bec
Frankenstein94
Oct 29, 2014 01:02 AM
wrench
Nov 3, 2007 12:05 PM
mikehogains
Oct 2, 2007 10:37 AM
bmarshall
Jan 3, 2007 08:54 PM
mbo1985
Mar 25, 2006 04:07 PM
