New guy needs help (accord)
Is the clock working.....just wondering if the fuse blew - no link to ecu when reading codes.
Edit: Also please add your car info to your signature......that way we don't have to go back to the first post to remember.
The clock does work, I have the crank pulley off to change CPS, will finish that up today. Would it be possible to take timing belt cover off and inspect it, turn it over, inspect it some more? Or is it not that simple? Thanks for all of the replies guys!
If you've already got the crank pulley off, then go ahead & remove the upper & lower timing covers. Check all the cam-timing marks to see whether the timing belt skipped. Inspect the teeth on the belt, or just use this as an excuse to put on a new timing belt.
Normally, the most difficult part of the timing belt job is removing the crankshaft pulley.
