new here 92 accord doesnt run good
Old Aug 21, 2011 | 03:12 AM
john's Avatar
Default new here 92 accord doesnt run good
hey i have a 92 accord lx f22a1 5speed. ever since i got the car it was always a little sluggish in 1st and 2nd below 2500 rpms. the problem is much worse taking off up a hill its almost impossible the car bogs and stutters until you make it up the hill or get above 2500 which takes much longer than past the hill most times. i recently tried to check the timing and found i could only see the 15 degree BTDC mark with my light hooked to the 4 cylinder spark plug wire i think that may have something to do with it but i want to find out because i have to change the timing belt to change the water pump so if my timing is jacked i could fix that too maybe. any help is much appreciated
Old Aug 29, 2011 | 12:33 AM
We will move this to a forum where it might get answered..
Make sure you ask questions in a better forum thread next time...
Old Aug 29, 2011 | 12:44 AM
Peli's Avatar
A good place to start would be with the EGR ports. They're pretty easy to check and clean.
Old Aug 29, 2011 | 03:42 AM
I marked the notches on my crank pulley with some whiteout to see the marks better with a timing light.
EGR port cleaning is a good idea. Also consider a tuneup. Spark plugs (only the NGK V-power plugs for your car), and inspect the distributor cap and rotor.
Google TSB 013 for a pdf on how to do this. It will be the first hit on your search.
Old Sep 11, 2011 | 03:35 PM
john's Avatar
hey guys thanks for the reply sorry to take so long my girlfriend crashed the car last week so we dont have it anymore im sure ill get another accord soon though
Old Sep 12, 2011 | 08:09 PM
Wow, sorry to hear that.
hondacars94
Jun 9, 2012 08:26 PM
franky831
Dec 8, 2010 08:01 PM
damninhell
Dec 7, 2010 08:36 PM
rmoreno17
Sep 16, 2009 11:35 AM
