New Honda owner - have quesitons about what is "normal"
Old Jan 4, 2008 | 08:55 PM
Chiovnidca's Avatar
Default RE: New Honda owner - have quesitons about what is "normal"
ORIGINAL: Contriver
2) Noisy valves when cold - I've noticed that when its cold, like this morning (it was 10 degrees Fahrenheit), the engine makes some clattering sounds, but it goes away when it warms up. Again, is this normal?
I cant hear it over the internet but it's probaly not valve noise. It's most likely piston slap since it goes away as the engine warms up. Nothing to be concerned about.
Old Jan 5, 2008 | 09:21 AM
smaglik's Avatar
1) normal,. my auto 07 did that.
wow, i must say i am really glad hondatechav6 joined this site...
Old Jan 10, 2008 | 07:52 PM
Contriver's Avatar
HondatechAV6 - The defroster doesn't seem to have an effect, however I'd still like to make sure that everything is connected...can you tell me how I can get access to the antenna coil? I don't see it. I assume it must not be in plain view. Do I have to remove a piece of molding to get to it? Thanks!
Old Jan 10, 2008 | 08:16 PM
Contriver's Avatar
One more thing, just curious...is it normal to havewires secured with electrical tape? A few wires behind the factory radio and in the trunk where secured with electrical tape. The tape was not used to cover a connection; it appears that its just keeping things tidy. Is this normal?
Old Jan 11, 2008 | 12:26 AM
nafango2's Avatar
yes this is normal. If you go under your steering column youll see more electrical tape than youve ever seen in your life! even yellow electical tape! ok not that much, but theres alot.
also id like to x2 on the whining in reverse, its perfectly normal. You see the reverse gear uses whats called a "spur" gear, which is used to make sure it cant be engaged while the car is in motion. All of the other gears in the transmission use "helical gears".
some transmissions are just more muffled than others for some reason.
Spur:
Helical:
esand003
Apr 26, 2014 05:12 PM
Angela_8875
Jul 11, 2012 11:47 AM
wangdaniol
Mar 18, 2008 07:49 AM
dbrs0821
Sep 17, 2006 11:58 PM
khedairys5
Sep 16, 2006 08:43 PM
