New Honda owner with some troubles
Hello everyone, after a lifetime of driving Toyota trucks and old model GM trucks I bought myself a 2002 Honda Accord 2.3 Vtec with auto tranny(244k). I am needing a cheap dependable car to drive back and forth to work.
The car has a CEL when I bought it but the previous owner assured me it was just an O2 sensor. The car ran fairly good for a week but has developed a rough idle sometimes, but sometimes it is fine. Also when kicking in the passing gear it will sometimes act like it is missing or cutting out while the tachometer flutters. Sometimes it does this, other times it doesn't.
I went by Oreilys and had them pull the codes. It showed P0401 egr flow insufficient detected as well as P1259 vvt electronic control system malfunction.
I did some reading online but am totally lost as to where to start. I did check oil level and can't see any dents in the pan. Thanks guys!! Please help this Honda newbie.
The code P1259 is a VTEC Malfunction. This could be something as simple as a pressure switch, or needing a complete valve replacement. You're going to want to test them first so you know which 1 is causing the code. The service manual has a great walk thru on testing the components.
I posted a link to downloadable Service manuals in another thread in this forum. I'll see if I can find it again.
Here it is.
http://www.hondahookup.com/forums/do...hp?do=cat&id=7
OneFastVette02
Jan 24, 2016 09:30 AM
