new locks
Old Jan 19, 2010 | 11:08 PM
riverman's Avatar
Question new locks
is it possible to replace all the locks in a 93 accord LX, doors,trunk, ignition?? The key i have now works only in the ignition, driver side door and only unlocks passenger side door.
Old Jan 20, 2010 | 12:18 AM
kris_loehr's Avatar
You can take your current locks to a lock smith and they can rekey to fit your key for the ignition . I used rekey them when I worked at a dealership.
Old Jan 20, 2010 | 09:13 PM
riverman's Avatar
And that key will work for all the locks on the car??
Old Jan 21, 2010 | 01:00 AM
kris_loehr's Avatar
As far as I know you can have all your locks rekeyed other than the ignition(someone probably can do that also) but you have to take or have someone remove them all. I used to just remove them and the locksmith rekey to the key I wanted it to fit then later did them myself. They just take the lock apart put in the key you want to use and change the tumblers until they are flush. If you have broken locks as you say the key doesn’t work in the driver’s door you may need a new lock.
Old Jan 21, 2010 | 05:07 AM
riverman's Avatar
key works in driver door, but it only unlocks on passenger side and dont work in the trunk lock.
Old Jan 21, 2010 | 05:09 AM
riverman's Avatar
oh forgot one more thing, driver side front lock. It works but when i press the lock for all doors on driver side it locks then unlocks. any ideas??
Old Jan 21, 2010 | 07:43 AM
Is that when the door is open? Does it do that when you're inside with the door closed? That's a FEATURE to prevent you from locking yourself out. Try holding the door-latch open while you press the lock button.
Old Jan 22, 2010 | 01:17 PM
riverman's Avatar
it only happens on the drive side side with the door open. driver lock works just fine if i lock from the passenger side.
Old Jan 25, 2010 | 06:57 AM
Like I said, that's a FEATURE - try holding the driver's door latch-lever open...
Old Jan 26, 2010 | 10:52 AM
riverman's Avatar
i will try that
trolddk
Jul 3, 2013 06:08 PM
rtijerina
Jul 25, 2006 01:25 AM
dphan2k1
Jul 12, 2006 01:20 AM
hurkes
Jun 23, 2006 01:51 PM
brownstreak
Dec 26, 2005 03:28 PM
