New master cylinder, mushy brakes
Old Aug 7, 2012 | 02:32 PM
duckytim's Avatar
Angry New master cylinder, mushy brakes
Small leak in master cyl, so had it replaced. Got it back from the shop, and the brakes are now very soft. Took it back, they rebled the brakes and it's now only slightly better. The pedal goes 2/3 down before noticeable stopping occurs. They were not soft before the cyl was replaced. Ideas?
I have a 2001 Accord EX 6-cyl with ABS.
Last edited by duckytim; Aug 7, 2012 at 02:55 PM. Reason: Left off car model and year
Old Aug 7, 2012 | 05:25 PM
Normally you want to bench-bleed the master cylinder before installing. Otherwise you have to bleed tons & tons of fluid. I've done this & it seems like you're done bleeding and the fluid comes out clear without bubbles.
But if you keep bleeding, eventually you get a few more bubbles then you're finally done.
Old Dec 31, 2015 | 08:01 PM
rubyshop's Avatar
I got my annual inspection passed 3 weeks ago, however I noticed leaking on driveway in different place. What may cause it? How is it possible it passed in first place if mechanic neglected checking all brake hoses etc.
Old Jan 4, 2016 | 01:49 PM
Where is it leaking? What fluid? Engine-oil? Water? Antifreeze? Windshield-washer-fluid? Not enough information to answer the question.
Old Jan 4, 2016 | 07:43 PM
rubyshop's Avatar
Tell me what color for each one u listed above. :/
Old Jan 4, 2016 | 08:28 PM
shipo's Avatar
Some of the colors vary; what color was the fluid you saw?
Old Jan 5, 2016 | 10:59 AM
First, was it oily or watery?
Does it smell sweet? Open the radiator (when its cold) & see if it smells the same.
Brake fluid has its own smell - open the master-cylinder fluid reservoir to compare.
Transmission fluid & engine oil feel similar, both oily.
PJ_STYLES_95AccordEx
Sep 27, 2014 11:57 AM
brassbanana
Feb 10, 2014 02:44 PM
Dr. Jimbo
Jul 27, 2009 09:35 PM
aso432
Oct 23, 2005 10:41 PM
gonecrazy
Oct 12, 2005 11:57 PM
