New top end vs reman engine
Old Feb 26, 2018 | 03:37 PM
  #111
TexomaAccord's Avatar
Cut ends off battery cables, ground cables, starter cable.. Cleaned connections... ZROOOMM! She lives!!
Old Feb 27, 2018 | 07:19 PM
  #112
Life back in the 5th gen....
Old Feb 28, 2018 | 06:23 AM
  #113
djkurious's Avatar
Glad you got her back up and running!
Old Feb 28, 2018 | 07:14 AM
  #114
shipo's Avatar
In the immortal words of Hannibal Smith, "I love it when a plan comes together." Congratulations.
Old Feb 28, 2018 | 01:13 PM
  #115
The Toecutter's Avatar
Definitely congrats on a job well done.
Old Mar 3, 2018 | 05:41 PM
  #116
Smoking real bad from front exhaust. Smells like oil burning. I don't see any leaks. Should I be concerned
Old Mar 3, 2018 | 07:25 PM
  #117
Now I'm thinking its all the PB Blaster I used on the exhaust... So I should be okay
Old Mar 4, 2018 | 02:03 PM
  #118
Yup, run it some more and see if it's still doing that.
Old Mar 11, 2018 | 09:40 PM
  #119
Originally Posted by PAhonda
Each fan should get power from separate relays. It is a design where one fan if a relay fails. If you have access to the original fan wires on the harness side, turn the key to the II position, then short the coolant temperature sensor A. Check if you have power and ground to those wires.
so unplug and jumper the 2 wires on Number 12?
https://www.hondapartsnow.com/parts-...v6.html?PNC=12
This fan conversation is being completed on the thread about fan issues. Will not be posting anymore about the fans in this thread.
Old Mar 15, 2018 | 12:54 PM
  #120
Up and running, still some bugs
