New top end vs reman engine
Old Dec 3, 2017 | 07:46 AM
  #21
#3 is gone.....why is the hard part. Could be the head gasket or something else. It's a hard call at this point, the engine is out so pulling the one head and having it checked and then putting it back vs. the replacement engine
Either way, I would think about doing the t-belt job and that (either engine) since you are that far into it.
Old Dec 3, 2017 | 08:46 AM
  #22
TexomaAccord's Avatar
My daughter said it was revving up by itself in park, which leads me to believe there was an air pocket in the coolant system. I do believe it got hot and just blew the head gasket. Also, this tdc sensor, that is the code I got when I checked it. Since the timing belt is going to get replaced, I'll do that as well. I wish I had filmed when I broke loose the pulley bolt for the timing belt. I put a breaker bar on it and just bumped the engine over and wa-la, bolt was broke loose. So simple. As for the replacement engine, this guy is dragging his feet about getting me pics and information, which is making my mind wonder as to why. If I had a good engine and was trying to sell and an eager buyer was requesting info, I'd jump on it to sell.. -- So that's leading me to just doing a top end rebuild on mine.
EDIT: Btw (for those that know me and my timing belt issue) I finally saw on the cover that the timing belt was last replaced in June 2008. The belt still looks brand new though, but still going to get replaced.
Old Dec 3, 2017 | 09:04 AM
  #23
Which brings me to a question about my tdc sensor.. Mine is a 4 pin, but all the ones I am finding that say they are for my car, are only showing a 2 pin. My 4 pin goes to 2 sensors, theirs goes to 1.. 37500P0GA01
EDIT -- Nevermind --
37841-P0G-A01
Old Dec 5, 2017 | 08:31 AM
  #24
Funny Tip -- When you use google, be more specific when looking up a cylinder head job.. never just look up "head job" -- cause google, well.. lololol
Old Dec 5, 2017 | 08:39 AM
  #25
shipo's Avatar
Historically, the term I've always used when referring to rebuilt heads is a "valve job". I can see how "head job" could yield some, ummm, interesting results.
Old Dec 5, 2017 | 01:08 PM
  #26
When you remove the intake and find extra parts lol
Old Dec 5, 2017 | 02:16 PM
  #27
Whats this white gunk? I can roll it between my fingers and it disolves
Old Dec 5, 2017 | 02:17 PM
  #28
Head gasket
Old Dec 5, 2017 | 02:50 PM
  #29
shipo's Avatar
The white gunk is typically from one or more of the following:
  • Use of incompatible coolants.
  • Waiting too long before flushing out exhausted coolant.
  • Use of stop-leak products.
Old Dec 5, 2017 | 03:32 PM
  #30
Pit marks, can it be fixed?
Is that my marker to how far it can be milled down?
