Newbie needs help with steering rack fittings
Old Sep 14, 2010 | 09:48 PM
MAGNET's Avatar
Exclamation Newbie needs help with steering rack fittings
Hey guys/gals,
Looking for advice on getting this power steering rack out of a 1997 accord. The main problem is the two fittings that came off of it and sit above the rear subframe are tight and very hard to get to.. I was wondering if anyone had any tips/pointers on how to get these fittings off... maybe if I drop the rack down I can slide it below the rear subframe and than loosen them?
Or is dropping the whole rear subframe the way to do it? Just trying to avoid taking the rear mount out.
I appreciate any advice on the power steering rack and pinion removal and installation.
Old Sep 15, 2010 | 02:19 AM
I have never removed the PS rack. I would suggest for you to get the 94 shop manual from the spooner link I posted in the online manuals thread in the main DIY section. It will have instructions on how to remove it.
Old Sep 15, 2010 | 08:15 AM
MAGNET's Avatar
I cant find that section.. I see the DIY section, as I searched high and low for accord steering rack input. Ill keep searching around, but a direct link would be super sweet! I appreciate your reply and care to help.
Old Sep 15, 2010 | 09:36 AM
MAGNET's Avatar
1997 Honda Accord 2dr Automatic 4cyl.
Need help with replacing steering rack.. main problem is the two fittings on the hard line.
Any link to a free manual, dont want to have to order and wait for a manual for the process of removing two bolts (there just in a real tough spot for the tool needed) (line wrench)
Thank you again.
Old Sep 15, 2010 | 12:05 PM
Here is the online manuals thread: Just click on the spooner link.
https://www.hondaaccordforum.com/for...ead.php?t=4597
Old Jan 29, 2012 | 03:29 PM
Kara Overton's Avatar
Thumbs up 1997 Honda Accord Steering Rack Help??
I was replacing my front brake pads with car on lift and right front tire toes in and out about 1/2 inch each way. The Left front does not do this. Is this a steering rack issue? or is this normal?? The ball joints are tight.
Any help?? If so where is the best place to purchase a new or remanufactured steering rack, as I only need this car to last about 12 more months. THANKS!
Old Jan 30, 2012 | 11:16 AM
Are you sure it's not the play in the steering wheel actually moving?
brandon0409
Feb 15, 2014 06:36 PM
on1accord
Nov 24, 2010 09:01 PM
Honda B Good
Jan 22, 2010 10:26 PM
Marffle
Apr 26, 2007 09:14 PM
im4an2idiot0
Jun 17, 2006 04:19 AM
