Bypass valve fittings
Old Apr 26, 2007 | 04:33 PM
Marffle
Default Bypass valve fittings
Does anyone have knowledge of how universally bypass valves tend to fit various cold air intakes? I'm planning on getting a cold air intake off of ebay due to my inability to afford something such as an AEM cold air intake at the moment and I want to get a bypass valve as safety measure. However, I want to make sure I get a bypass valve that is going to fit. I've also found bypass valves on ebay. Any advice?
Old Apr 26, 2007 | 05:30 PM
Shadow1992's Avatar
Default RE: Bypass valve fittings
Once again these aren't the cheapest, but as long as you get the one that is the same size as your intake diameter, it should fit fine. Most intakes tend to be of the 2.5 inch size or 3 inch.
http://www.aempower.com/ViewCategory.aspx?CategoryID=20
Old Apr 26, 2007 | 05:40 PM
sir_nasty's Avatar
Bypass valves are fit just to diameter so as long as the one you order fits the same diameter piping you get it will work just fine
Old Apr 26, 2007 | 09:14 PM
19Accord97
^Agreed
You can also special order them from Advance Auto Parts
MAGNET
Jan 30, 2012 11:16 AM
Honda B Good
Jan 22, 2010 10:26 PM
thunder_x
Oct 6, 2006 07:10 PM
im4an2idiot0
Jun 17, 2006 04:19 AM
dave118811
Jun 8, 2006 02:08 AM
