NM/NC Speed Sensors Removal
Old Feb 14, 2013 | 06:51 PM
renzki's Avatar
Smile NM/NC Speed Sensors Removal
Hello All,
Whats the best way to remove these sensors? I wanted to clean them and test resistance. Car jerks when shifting and I read somewhere in this forum that dirty sensors might be a culprit. The space to access them is really restricted and I dont know which tools will work for such confined space
Thanks!
Old Feb 14, 2013 | 06:57 PM
Looks like battery and battery tray/support need to be removed.
Is D4 light flashing? Even if not, check for trans codes. Some don't set the d4 light flashing.
Old Feb 14, 2013 | 07:07 PM
renzki's Avatar
The D4 flashing happened like twice last year (few months gap). I didnt count how many times. I just put the car to rest for about 5 minutes that last time and it never happened again ever since (months passed already). Also car wont shift to 2nd gear on very cold mornings. I have had to run the car for like more than 3 minutes before it would shift to 2nd and up again (jerk is always there though)
Old Feb 14, 2013 | 07:14 PM
Check for codes anyway as explained.
Suggest checking trans throttle cable adjustment. Throttle plate and trans feedback lever should begin to move at same time.
Old Feb 16, 2013 | 02:33 PM
renzki's Avatar
No codes and both throttle plate and trans feedback lever begin to move at the same time. i then again attempted to remove the speed sensor thats found behind and i couldnt fit any tool
Old Feb 16, 2013 | 03:35 PM
When was the last time you drained and refilled the transmission fluid?
It is not the sensors that you read about, it is the solenoids. A bad sensor should set a code. They are bolted on the transmission and look like this:
Unbolt those and clean the screen and solenoid with some throttle body cleaner.
The TCU is another item can go bad on these cars. You may want to open up the TCU and look for any signs of damaged capacitors or burnt components on that board.
Old Feb 16, 2013 | 11:06 PM
renzki's Avatar
Drained and refilled the transmission fluid about 2 months ago. I will try to clean the solenoid valve tomorrow. Ive been reading this article so ill try to review the steps tomorrow
Thanks!
socaldave34
Oct 18, 2012 06:09 PM
irhunter
Mar 23, 2011 04:49 PM
Spadinator
Oct 23, 2010 12:50 PM
enerlevel
Sep 5, 2005 02:26 AM
Rasher
May 17, 2005 01:19 AM
