No Crank, No Start ignition.
Old Jun 10, 2018 | 03:51 AM
raidmax's Avatar
Default No Crank, No Start ignition.
So I've been tackling this issue for almost a month now, and still getting no where. I have a 1996 accord v6, when I turn on the car there is no cranking. I bought all new, alternator, battery, starter, and ignition switch. and nothing seems to work still. the only thing that would turn on the car is if I take a wire and place one end to the positive battery terminal and tap the starter solenoid it starts right up while the key is turn to the 2 position or 3rd forgot but just before the last. can someone help ? Is this a typical sign of a bad Neutral Safety Switch? I would like to know before I go spending more money on parts that I don't need.
Old Jun 10, 2018 | 11:30 AM
You should investigate whether small blk/wht wire at the starter is receiving a 12v start signal. It likely is not based on your jumper test
Next check whether start relay is getting power, ground, and control signal (keyswitch) to start. A wiring diagam is essential. Check BBB Industries free info.
N4chtm4hr
Jul 28, 2014 08:30 PM
shehadehd
Sep 20, 2012 05:20 PM
dimbee
Oct 12, 2007 02:52 PM
jrparks
Sep 13, 2007 08:16 AM
wietgr
Jun 13, 2007 06:41 PM
