No floor heat on 2004 Honda Accord
Old Sep 12, 2014 | 09:22 AM
wdg67's Avatar
Default No floor heat on 2004 Honda Accord
I noticed last winter that I was not getting any floor heat in my 2004 Accord. The top vents work fine. The AC is working although I was told it might have a leak as it gets cool but not cold (still comfortable though). The display light on my sound system is also out, I don't know if that's related at all.
Any ideas as to what this might be and how expensive it would be to fix?
Thanks in advance for your help.
Old Sep 12, 2014 | 11:31 AM
This could as simple as a sticking mode control lever or much more complex.
The mode control motor is located pass center of the car - open and lower the glove box (the little latches that keep it from falling all the way down - remove them so the box does lower all the way) and you should be able to "see" it. Look through the glove box opening towards the center of the car.
Once the box is down, key to "on" and cycle the modes from vent/windshield/ect and you should see the motor moving some levers/arms. When going to "floor", do the levers start to move and stop....what happens if you give the a gentle push....
Old Sep 12, 2014 | 11:48 AM
wdg67's Avatar
I will definitely try this but I think it might be more complex as I feel air blowing from the floor vents, it's just not hot. The top vents blow hot air.
Any idea as to how much it would cost to fix this?
Old Sep 12, 2014 | 02:51 PM
YeuEmMaiMai's Avatar
a lot of people have had success disassembling the blend door and actuator and re lubricating it.
as for the head unit, it will have to be repaired. it is a known issue with the system where the backlight goes out.
Old Sep 15, 2014 | 09:48 AM
wdg67's Avatar
Unfortunately, I do not have the mechanical skills to do that job. How much would it cost if I took it to a professional?
Old Sep 15, 2014 | 09:27 PM
Since I do some things myself, I can't answer the cost for a shop to do the work.
I'd like to ask another question or two.
If you set it to "floor" heat only what kind of heat are you getting?
If you have it set to Def/floor what kind of heat do you get on the floor?
Have you had the cabin air filter replaced recently?
Old Sep 16, 2014 | 06:27 AM
wdg67's Avatar
When I set it to "floor" heat only, I get air blowing but it's not hot at all.
When I set it to Def/Floor, I get air blowing but no heat at all although the defogger works.
I can't remember the last time I had the cabin air filter replaced.
Old Sep 17, 2014 | 08:25 PM
Just a reach but the cabin air filter should be replaced about once a year or more.
There are DIY was to get codes from the hvac system but again if you don't know the last time the cabin air filter was changed- start there as it is a maint item and we need to rule it out.
Old Sep 18, 2014 | 01:37 PM
The issue sounds more like a problem with the air mix control linkage, door, or motor. The air mix control motor is located under the center dash area (driver's side).
If it is only the air mix control motor, the Honda part list for $68.27. Labor probably about half hour charge if you pay a shop to change it without diagnosis. That is if it only is the motor.
From your description, it sounds like the mode control motor may be okay. Air cabin filter shouldn't cause what you're describing.
Following this link to see if there are trouble code(s) to possibly narrow down the heat issue.
https://www.hondaaccordforum.com/for...-code-s-34589/
Old Sep 19, 2014 | 12:44 PM
wdg67's Avatar
Thanks!! I will check the codes this weekend. I'm taking it in for a Fall checkup next weekend, if the codes can help narrow down the problem, I may get it fixed then.
skijour
Aug 15, 2012 08:31 PM
flynbetty
Mar 31, 2011 06:11 PM
Cessna172
Nov 5, 2010 01:22 PM
ebrsales
Mar 31, 2010 10:08 AM
mafzal
Mar 26, 2009 07:45 PM
