No gauges
Old Feb 18, 2025 | 03:15 PM
csduncan22's Avatar
Default No gauges
I hooked up a camera to my 2006 accord and it worked for a while then I tried it again and dash is dead no warning lights the car won’t go into gear and windows don’t work now all from tapping into the reverse lights omg any idea tks
Old Feb 18, 2025 | 07:37 PM
With so many items not working, check your fuses.
Old Feb 19, 2025 | 08:42 AM
csduncan22's Avatar
Do these look good?
Old Feb 19, 2025 | 07:58 PM
dtnieberding's Avatar
Originally Posted by csduncan22
Do these look good?
Those don't look like fuses. They might be relays. I can't quite tell from that angle. Where did you pull them from?
Old Feb 19, 2025 | 08:09 PM
First, disconnect that camera. It may have caused this. Second, I'd check all your fuses. Do you have a multimeter, or something that will check continuity? Pull each fuse, one at a time, and check for continuity. If you find a blown fuse, take note of which one it is, and replace it.
On my 1998 Accord, the brake lights, horn, and shift interlock are all on the same circuit. So when that fuse blew, I could not shift out of park (without bypassing the interlock). On mine, that fuse is labeled "STOP" and it's located in the fuse box under the hood. If your 2006 is wired the same, you should definitely check that fuse. But you also have more issues than just that circuit, so check them all.
When you fix this, don't wire the camera back into the taillights. You should run a separate circuit to the camera. It may have been pulling too much current through the tail lights circuit (I don't know why, because any current for a camera should be negligible).
Old Feb 20, 2025 | 08:09 AM
csduncan22's Avatar
I threw camera in the garbage it’s going to the garage today I pulled every fuse and none were bad tks all for help
Old Feb 20, 2025 | 10:52 AM
I wouldn't have thrown the camera out. I'm sure it's fine, if wired properly.
So all the fuses are good? Did you find/fix the problem?
Blackwater
Jan 3, 2020 09:14 AM
Fazeelbajwa
Aug 23, 2018 04:24 PM
billyspvy
Aug 4, 2012 03:31 PM
logan
May 27, 2008 12:29 AM
oldaccord
Oct 13, 2005 02:56 AM
