No Power To Third Brake Light
Old Jan 30, 2013 | 04:45 PM
toniboicb7's Avatar
Default No Power To Third Brake Light
I recently replaced 1 of the harnesses on my brake lights and I'm at the brake light won't work. I replaced the right rear brake light harness, I don't mean the entire harness I just mean 3 piece connectors that connects to the sockets. after I get that my third brake light stopped working, I used a multimeter and still no power. the socket is good I tried it direct power there's just no power going to it to light up the bulb. should I replace the harness again.
Old Jan 30, 2013 | 05:38 PM
Can we start with what year the car is?
Might add the info to your signature so you don't forget this going forward.
Old Jan 31, 2013 | 11:48 AM
toniboicb7's Avatar
Its a 93 Accord coupe also known as Cb7's (90-93 Accords) I take pictures of the harness in talking about.
Old Jan 31, 2013 | 12:09 PM
toniboicb7's Avatar
the old right harness was bad and I had to wiggle it so I can get the right brake light and the center light to turn on. I replaced it the wires work quite the same but it made the brake light work on the right except for the third brake center light.
RIGHT HARNESS
CENTER HARNESS I REMOVED TO TEST HAVE NOT REPLACED IT YET.
Old Jan 31, 2013 | 05:17 PM
Check the GRN/YEL wire coming out of the failure sensor for voltage when the brake pedal is pressed.
Honda Bill
Apr 19, 2024 10:11 PM
tglandon
Apr 26, 2015 12:21 AM
ETH13
Feb 8, 2013 03:43 PM
MOTORBIKE
Jul 25, 2012 06:57 PM
slammed accord
May 30, 2012 09:53 PM
