No shift, no reverse 92 Accord
Old Sep 9, 2015 | 07:13 PM
  #21
Turtlehead's Avatar
It does looks as if the board is fried. If you replace it again and the problem reoccurs then beware there is likely a fault in the electrical causing the board to fry.
Old Sep 9, 2015 | 08:02 PM
  #22
I think the car still will not shift or go into reverse.
Did you ever find the pdf of that shop manual I referenced in an earlier post for the 1993 accord?
Old Sep 9, 2015 | 08:10 PM
  #23
If you manually shift the car from 1,2,D3,D4. Which gears work?
Old Sep 9, 2015 | 08:14 PM
  #24
Honda_Lady's Avatar
I must have missed the PDF file, I'll be sure to look at it.
1 and 2 work, manually shifting to them.
Old Sep 9, 2015 | 10:36 PM
  #25
I just posted a file name to search on the web.
I'm trying to stick to simple stuff before condemning the transmission. Try adjusting the shift cable. There should be a procedure in that shop manual on how to do it.
Old Sep 9, 2015 | 11:37 PM
  #26
Honda_Lady's Avatar
Ok, thank you, I'll check it out.
Old Sep 10, 2015 | 02:28 PM
  #27
Honda_Lady's Avatar
Slight improvement in power of the two gears I have, still no automatic shifting or reverse. There didn't appear to be enough clutch material come out during drain and fills, and I have a shift solenoid A code on the TCU, is there still hope? I don't know.
When moving the shifter into reverse, I hear a click, and nothing else.
Old Sep 10, 2015 | 07:15 PM
  #28
Did you try to adjust the shift cable?
Old Sep 10, 2015 | 10:10 PM
  #29
Honda_Lady's Avatar
I didn't have time today, I will attempt it tomorrow.
Old Sep 11, 2015 | 03:08 PM
  #30
Honda_Lady's Avatar
:/ attempted to get that file to adjust the shift cable, also tried looking for a video, only found brief instructions on removing it, I'll keep trying.
