No start 92 Accord
Old Feb 16, 2020 | 11:11 AM
Mandriva1's Avatar
Default No start 92 Accord
I have a Accord that I received from a friend ,the car sat since 07 .I have replaced the injectors .tank ,lines and filter and the car ran well for about a week . Now I have a no start issue I trouble shooted a distributor issue with the manual and codes replaced the distributor along with the coil . Still no change it has spark at each plug long with about 40 pounds of fuel pressure also checked the main relay . Any thoughts out there on what next....first time posting here
Old Feb 16, 2020 | 11:46 AM
I'd start with the simple stuff first. Look at the distributor cap from the passenger side of the engine bay. Find the spark plug wire that goes to the #1 cylinder (closest to driver's side of the engine bay). The next spark plug wire going clockwise should go to #3, next is #4, and last is #2.
It is possible to install the distributor 180 degrees out of time (guess how I know?). Do you know how to get the engine to top dead center?
Old Feb 16, 2020 | 12:33 PM
Mandriva1's Avatar
I found tdc and I feel like distributor is installed correctly but I will make sure it's not 180 out .
Old Feb 16, 2020 | 01:17 PM
Mandriva1's Avatar
Also curious if there is a crank sensor in or out side of the distributor maybe somewhere near the timing belt cover.
Old Feb 16, 2020 | 03:10 PM
Unless it's been swapped around for an OBD-2 engine, all the timing sensors are inside the distributor. The CKP sensor being at the crankshaft pulley didn't start until 1996.
Old Feb 17, 2020 | 11:21 AM
The Toecutter's Avatar
Since you're getting some spark, try giving the engine a shot or 2 of starting fluid, either thru the air cleaner snorkel, or the brake booster vac hose. This will tell you if you have a spark issue, or a fuel issue. I realize you have good fuel pressure, but are the injectors working? Hence the reason for shooting some starting fluid into it. It should either start and try to run, or pop from being timed wrong, or you'll get nothing (spark related).
Caleb Wilson
Nov 8, 2014 09:02 AM
craven12
Dec 3, 2012 12:26 PM
happenin honda
Oct 18, 2011 11:28 AM
indianawagon
Jun 15, 2011 06:59 PM
timhillu03
Dec 4, 2005 10:40 PM
