92 Accord Starting Woes
Old Jun 15, 2011 | 06:19 AM
indianawagon's Avatar
Default 92 Accord Starting Woes
I have a 92 Accord that I bought and it was not running at the time. I was told it was a fuel pump and the owner did not want to fix it. After diagnosing the issue it turned out to be the distributor. I replaced the whole distributor, plug wires, and plugs. The car ran great. After a while I noticed the car taking a little longer cranking before starting. This cranking issue continued to get worse as time went on. Then about 6 months after replacing distributor it would not start up after it was hot. It needed to cool down before it would start again. It was found to be a bad distributor. When I returned it for the warranty, I was told it looked like it had gotten hot. Now jump forward about 4 months and its starting to show some of the same signs as before.
Is there something I should be looking for?
Old Jun 15, 2011 | 06:59 PM
Get it tested. If bad, have it replaced. Double check the pins to be sure they are clean.
I could see if there were other issues, wire(s) grounding and that, but that would show up in the cars performace long before the ICM gave out....IMO.
BigNiner19
Mar 20, 2015 01:38 PM
adamswt
Oct 21, 2009 01:48 AM
adamswt
Oct 20, 2009 07:29 PM
Blenton
Jun 20, 2008 06:54 PM
Brendo613
Feb 23, 2006 07:26 PM
