NO start problem
Old Feb 22, 2008 | 11:39 PM
wagon_sc's Avatar
Default RE: NO start problem
ok now i fixed one problem and made another i got a new dizzy put in well with the help of my girlfriends brother which i think made the second problem. he just yanked out the old one and tryed putting in the new one now it won't start. bad timeing. any hints or threads that anyone can throgh this way.
Old Feb 23, 2008 | 09:06 AM
I hope he didn't put the distributor in upside down. It's possible, but the distributor will not fit well and when tightened may be damaged. Guess how I know!
Also, the distributor can be assembled (assembly error) 180 degrees off w/ the drive lug rotated. If you align the crankshaft w/ the 15 degBTDC timing mark (red mark), the distributor rotor should be pointed directly at the #1 distributor spark tower. If it's in opposite direction, the distributor drive key will need to be removed, rotated 180, and reinstalled. I managed to do this one also while changing the distributor oring.
Old Feb 23, 2008 | 09:50 AM
wagon_sc's Avatar
were can i see the marks so i can align the crank with the BTDC. also since i wasn't the only one messing with it i think the order of the wires are messed up
right now they are in 4 3 1234 1234 being from left to right and the dizy being looked at from the passenger side.
2 1
Old Feb 23, 2008 | 10:13 AM
No. 1 tower is at about 1 o'clock position when looking at from side standing by RF fender. Order CW is 1-3-4-2. Looks like wires are misaligned.
Timing marks (90 Accord) are on the flywheel. A rubber grommet on front side of engine below/forward of the distributor is removed to access the flywheel view. Pointer is visible when grommet is removed.
Old Feb 23, 2008 | 10:24 AM
mjrthreat
could you tell me how to get my check engine light to stay off , like permanently?
Old Feb 23, 2008 | 11:30 AM
wagon_sc's Avatar
ORIGINAL: mjrthreat
first you need to find out what the problem is. get it checked by autozone if it is a obII and if its older than 96 then do the check your self and find out whats wrong with it and the light should come off. never perminantly until something else brakes.
what kind of car and year is it.
Old Feb 23, 2008 | 02:24 PM
  #17
wagon_sc's Avatar
problem fixed thanks guys for the info. new dizy and re arange the plug wires and its all good
Old Feb 23, 2008 | 10:17 PM
  #18
Two replacement distributors? Was misplaced wires the reason for failure to start after distributor installation?
Old Feb 23, 2008 | 11:01 PM
  #19
ORIGINAL: mjrthreat
There is one way to get it to go off besides erasing the code and that's to take care of the problem where it will then go out...If you erase codes you only are fooling yourself...
Old Feb 25, 2008 | 10:45 AM
  #20
ORIGINAL: WheelBrokerAng
Besides, if you clear the codes, they won't stay cleared. Every time you run the engine, the ECU will 'discover' that the problem is still there.
Tony1M
Nov 6, 2023 08:29 PM
gasface11
Jul 11, 2012 12:33 PM
bpethomas
Jun 5, 2012 10:47 AM
kellysa111
May 1, 2009 08:35 AM
brickballer
Apr 18, 2008 04:25 PM
