No Start Problem
Old Jul 12, 2015 | 10:52 PM
richart's Avatar
Default No Start Problem
I have 2000 accord v6 coupe. The car won't start when the weather is hot can anybody tell me what is the problem I did tune up new battery and fuel injection cleaning
Old Jul 13, 2015 | 08:31 AM
Suggest checking small blk/wht wire to the starter for 12V start signal when start command (Key to start position) is present.
If 12V present, then starter is faulty (starter solenoid or other internal fault). Replace starter.
If 12V missing, then ignition switch, starter cut relay, or wiring fault (open circuit from damaged wire). Starter cut relay is under the driver's dash area.
Tony1M
Nov 6, 2023 08:29 PM
gasface11
Jul 11, 2012 12:33 PM
bpethomas
Jun 5, 2012 10:47 AM
kellysa111
May 1, 2009 08:35 AM
brickballer
Apr 18, 2008 04:25 PM
