Noisy clutch pedal
Old May 3, 2007 | 10:05 AM
matash
Default Noisy clutch pedal
I have a 2003 Accord EX-L 5 speed with original clutch (83,000 miles). Recently I have been experiencing a periodic "hitch" in the clutch pedal accompanied by a clicking noise. The shifting operation is not affected and the car is running fine, but the pedal mechanism doesn't feel as smooth as it used to. Has anybody else run into this?
Old May 3, 2007 | 12:57 PM
otsb708's Avatar
Almost A Senior Member
Default RE: Noisy clutch pedal
Sounds like the early signs of clutch failure.
Old May 3, 2007 | 02:39 PM
You could have someone work the pedal while you watch the throw-out lever on the tranny. If the hitch is accompanied by a funny action in the lever, then the trouble is in the clutch (inside the bellhousing). If not, then the trouble seems to be external, in the hydraulic system.
bunkrd you
Apr 9, 2016 11:34 AM
3XHonda
Apr 4, 2013 11:27 PM
robertomiguel
Mar 25, 2008 10:45 AM
robertomiguel
Mar 24, 2008 07:25 AM
tamb
Jul 21, 2006 01:05 AM
