o2 sensor
Old Oct 21, 2008 | 02:07 PM
Mdschmidt's Avatar
Default o2 sensor
Im looking to install an air/fuel guage but is says only for narrow band senor so would this work for my 94 accord?
Old Oct 21, 2008 | 02:12 PM
finch13's Avatar
Default RE: o2 sensor
An A/F Ratio gauge (aka EGT) uses a wideband O2 sensor to get it's readings... what particular model are you looking at?
The OE O2 sensors are narrowband, wideband sensors are like $150+.
Old Oct 21, 2008 | 03:04 PM
Mdschmidt's Avatar
I don't remember the brand a/f but I kno it said it only works with the narrowband sensor and I have an oe one so I should be good then right?
Old Oct 21, 2008 | 03:21 PM
finch13's Avatar
You should be fine then...
I don't know why anyone would want an A/F gauge if they aren't tuning, especially if they aren't using a wideband sensor, but to each his own. The narrowband sensor really only displays if you are running rich or lean, whereas a wideband will tell you how rich or lean multiple times a second.
pondrun
Nov 8, 2021 09:40 AM
elessar78
Feb 4, 2010 03:30 PM
dmost30
Sep 8, 2008 12:42 AM
dmost30
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
