O2 sensor questions
Hey Guy's recently had CEL pop up so I scaned it with an Actron and it came back the o2 sesor.So I shopped it and found that Amazon had the best deal. I ended up with a Denso 234-4095 which should be an Oem match.It looks idntical to whats in my car with the exception of the plug which is a male instead of what it should be a female? What happened here? Is this sensor compatable? Can I simply but splice tne old plug? Or do I have to go the the hassel of return by mail?
Thanks
Thanks
Sorry it's a late 95 F22B2 obd 2 The code is Po135. O2 sensor heater circuit bank 1 sensor. Thisshould be corect according to the nominclature on the web sight that I bought it from? Only the plug is male instead of female. Can the old plug be swapped?
Thanks
Thanks
As I said late in model year. And it does have the tails in the trunk lid...It actually says its a 11/ 95 on the date so in car sales that means its a 96. Anyway what do you make of this sensor being male ended when it should be female?.?
"http://www.oxygensensors.com/catalog.php?&pkey=1167410"
The 96 Accord LX, DX, (F22B2) direct fit Denso is 234-4620.
"http://www.oxygensensors.com/catalog.php?&pkey=1167454"
So incorrect part number. But, yes, if you want to splice the old plug onto the new sensor, it will work. As you will notice from the above links, the Walker universal O2 sensor is 250-24200 for both LX and EX.
Just in case your O2 wire colors are different, here is a cross-reference and splicing guide.
"http://www.sparkplugs.com/glossaryImage.asp?imgID=271"
"http://www.sparkplugs.com/sparkplug411.asp?kw=Universal+O2+Sensor+Installati on+Instructions&mfid=0"
Sorry, I stepped out for a while.
Every time I paste that site's direct link, it redirects. So, I added the quotation marks. Copy and paste the link address without the quotation marks (" ").
See my attached images or the screenshots. The second link will redirect; but, then go to the area I marked in the image.
Let me know if you can get it to work.
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
