OBD II scan tool question
Old May 8, 2006 | 06:12 AM
FlyLow's Avatar
Default OBD II scan tool question
Has anyone used a Creader scan tool made by Launch, i checked one honda that had a code (or at least the check engine light came on), and two hondas without codes and got same results. As in no code, but four dashes lighting in sequence one after another with a pause before last dash and then an "E". i wonder if it means Error or Empty or what. The manual says if there are no codes you'll see the four dashes, but there is nothing in the manual about an "E". So i wonder if this tool doesn't like hondas or is what. Is it possible that the check engine light came on but without a code? I reset the light using the battery disconnect technique, and it hasn't come back yet.
99' Accord LX coupe
bengreendc
Nov 21, 2013 07:23 AM
caliazaccord
Feb 7, 2013 10:59 PM
dragonle87
Oct 5, 2009 09:53 AM
dragonle87
Oct 4, 2009 08:54 PM
choffman41
Jan 31, 2007 09:09 AM
