Odd Issue With Starting
Old Jan 26, 2024 | 11:43 PM
Emro's Avatar
Default Odd Issue With Starting
I have a 2008 Honda Accord EX 3.5L V6, with 152k mileage.
Sometimes (not always) when I try to start the car, it doesn’t start — there is no crank, the lights on the dashboard and electrics turn on fully illuminated but no crank at all. In some cases there is a small crank but doesn’t fully start, but typically there is no crank at all.
I have a new alternator (installed this month), somewhat new starter (installed Dec 2022), battery has been tested at Honda (reported good).
The way I deal with it when it does not start is that I turn on the car (dashboard lights, etc) and I shift out from P to another gear like N, then back to P, afterwards I crank the car and it magically starts up. This technique regularly works, very rarely does this Not work (1 or 2 instances not worked) otherwise I would probably just keep cranking again and again.
I would appreciate any advice or insights on this, thank you.
Old Jan 27, 2024 | 10:28 AM
No crank either means no 12V signal is getting to the starter to start the motor or the starter solenoid is not making contact.
When you have the no-start, do you hear a loud click from the engine bay?
scw65
Dec 10, 2023 08:06 PM
robc
Apr 27, 2022 07:52 PM
Jfrav
Mar 8, 2022 05:44 PM
serverus13
Jun 16, 2014 08:19 PM
slicnarf
Nov 26, 2007 12:19 PM
