1996 honda accord LX automatic no crank no start
Old Jun 15, 2014 | 12:33 PM
serverus13's Avatar
Default 1996 honda accord LX automatic no crank no start
Hi everyone i just signed up today so bare with me.My honda went out on me on this past Sunday .I thought it was a bad starter turns it is was.I took the old one to O'rellys and they tested it and sad it was bad.Great so i replaced it and it still wouldn't start no crank or anything .I had to jump it.So iam thinking it the battery i get that tested also and its good .So after a while i can start it no problems but when i drive it for some time (engine gets hot ) and shut it off then it wont start again no crank or anything just a click .I have to let it sit then it will start back up .I can hear the fuel pump turn on so i dont think it the main relay ? any answers? Also no check engine lights either ,Please help
Old Jun 15, 2014 | 01:26 PM
LS-300's Avatar
Check the connections to see if they are clean and tight.
Old Jun 15, 2014 | 01:30 PM
serverus13's Avatar
yea i checked the battery connections everything looks in order
Old Jun 15, 2014 | 02:27 PM
How about the other end of each battery cable?
Old Jun 16, 2014 | 09:07 AM
LS-300's Avatar
Since the car only does it when hot it would lead me to believe the cables are not clean at one end or the other. Next I would check to see where they are routed. Are they close to a major heat source? I.E Exhaust system? Then I would look again at the starter. It may be new but I bet it's a rebuilt one not actually new. They sometimes screw up rebuilding them so you may still have a bad starter.
Old Jun 16, 2014 | 06:07 PM
serverus13's Avatar
ok thanks guys i took the rebuilt one back to orellys and they gave me another one .It works some what better but it still doesnt come on right away.Like theres a just a click.After waiting like 5-10 mins then it comes on right away .iam not sure what that it .All the fuses check out .Should i replace the battery cables?
Old Jun 16, 2014 | 06:14 PM
Old Jun 16, 2014 | 08:19 PM
serverus13's Avatar
Thanks i will also look at the alternator to
fading
Oct 15, 2012 09:20 PM
75aces
Dec 15, 2010 02:46 AM
uraceulose
Nov 6, 2010 09:32 AM
Derek Sithol
Jan 19, 2010 12:37 AM
xang0
Jul 6, 2009 03:22 PM
