Odometer not working
1994 Honda Accord EX, Odometer quit working at 160,499 as it was rolling to 160,500. Speedometer still works fine, Trip meter doesn't work either. Is it a bad gear in the odometer or could it be a loose connection? Any ideas?
Thanks!
Thanks!
try pushing your trip reset then insert the key to the left of the odometer and reset the "maintence req." indicator, sometimes that will make your odometer start working again. If it doesn't you can check your connections but most likely your speedo/odo went bad. It's a common problem for 94-97 accords. Mine was replaced at 136k miles...
