Odometer not working
Old May 21, 2007 | 10:21 AM
Drpepper's Avatar
Default Odometer not working
1994 Honda Accord EX, Odometer quit working at 160,499 as it was rolling to 160,500. Speedometer still works fine, Trip meter doesn't work either. Is it a bad gear in the odometer or could it be a loose connection? Any ideas?
Thanks!
Old May 21, 2007 | 01:10 PM
sir_nasty's Avatar
Default RE: Odometer not working
try pushing your trip reset then insert the key to the left of the odometer and reset the "maintence req." indicator, sometimes that will make your odometer start working again. If it doesn't you can check your connections but most likely your speedo/odo went bad. It's a common problem for 94-97 accords. Mine was replaced at 136k miles...
Old May 22, 2007 | 12:20 AM
Drpepper's Avatar
You are my hero (for now anyway!) Pushing pressing the trip reset and maintenance reset at the same time worked!
I wish they were all that easy
Thanks again!
jackmd
Sep 15, 2011 06:11 PM
junior7389
Jun 30, 2010 09:57 AM
986ci's
Jul 6, 2009 07:31 AM
Jim88
Jun 20, 2008 10:36 PM
RockYork
Feb 24, 2008 08:13 PM
