OEM vs aftermarket (Moog) bushings & ball joints?
My son is off to college for the semester, and with his car sitting in front of the house I figure now is a good time to do a sweep through the suspension, replacing the remainder of the rubber bushings and ball joints that I haven't gotten to yet.
Q1: I've checked online, and surprisingly Honda OEM bushings and front lower ball joints are less expensive than Moog. Should I just buy OEM, or are Moog unusually stronger/stiffer than OEM that it is worth getting Moog?
Q2: The shock mount bushings (pair of rubber donuts at the top of all four shocks) are very expensive with OEM, more than 2x the price of aftermarket. Is there a reason that would warrant paying the premium for OEM, or should I just get a good aftermarket set?
Thanks. John
Thanks. John
I'd go with Honda stuff where the price is "right", if not then Moog is a good option.
As far as the ball joints - the only "plus" for the moog is I think you can grease them.....but then you have to think about how long the original ones lasted without adding grease
Only some of the Moog joints are greaseable ... they seem to switch back and forth, even within the same part numbers. I personally don't want greaseable joints -- that implies that the joints don't hold their lubrication well and they require periodic maintenance. The recommendation I saw in the instructions for Toyota sway bar links that I recently bought (and subsequently returned) was to grease twice a year. Ugh ... when the sealed joints last for 7+ years? All of our European and Japanese cars use sealed joints so I see no reason to switch over and just create more maintenance work for myself.
So no issues with the Honda house brand ball joints or bushings being cheap or weak? if not, looks like I'm going to be buying mostly OEM then ...
In the shop we have found that aftermarket greasable joints fail more often than non-greasable. Domestics quite often have the grease fittings and fail a lot more.
Polyurthane bushings are a very good option if you want durability. They're worth it.
If you dont want polyurthane then with shock mount bushings go with OEM just because they're rather hard to replace. You want something you dont wanna touch again. With the quick stuff I always go with cheap ebay- control arms and tie rod ends. Prime choice auto parts is really good with my 97 parts.
Upper ball joint is an easy replacement that you replace with the upper control arm. The part is cheap on ebay. Lower ball joint is a pain whether its pressed on the knuckle or the lower control arm. You want something that lasts.
For the bottom shock mount I already purchased Moog a long time ago, so not worried about that.
Easiest suspension part replacement yet!
Im sure there are fair arguments for greasable fittings but I don't trust them.
I have a few polyurthane bushings for performance reasons. No problems with them yet and they're guaranteed to last longer than rubber ones.
For parts, have you been searching ebay or amazon? You can get OEM parts for cheap too.
To replace the shock mount bushings you will have to use a spring compressor, the process can be rather dangerous which is why its not a typical repair unless there is an obvious problem. Only bushing I've replaced was on a car that was making noise when turning- the bushing was obviously worn. Other than that the bushing is usually replaced at the same time as the struts and springs.
In the process of replacing springs and struts, I left the old spring seat rubber and top shock mount rubber in place because at the time I thought they still looked fine. Now as I change out other parts on the cars I'm realizing that even though old rubber still may look good, since it has been compressed over time that can make a difference in operation.
Btw, the Accord springs are nothing to compress. You should try Mercedes w203 front springs -- they're a chore ...
So is the issue with greasable joints. I think they fail largely due to insufficient maintenance.
Polyurthane bushings are stiffer, which is why they're used more for performance applications. But they also last longer and perform better. I look at them as good for Hondas and other economy cars, not so good for luxury cars where the owner is paying for a smooth ride.
jo_accord
Jul 16, 2008 11:05 PM
Oct 11, 2005 05:58 PM
