oil for accord 95 manual
Old Jan 23, 2008 | 09:14 PM
tru3_k177's Avatar
Default oil for accord 95 manual
hey guys...
just an opinion...
i have an accord 95 that ussually run at about 100-130KPHon general driving daily...
and just wondering what is the best oil grade/temp for this kind of driving?
or it doesn't matter at all?
thanx
Old Jan 23, 2008 | 09:16 PM
eric123's Avatar
Default RE: oil for accord 95 manual
Where are you from, how low does the temp get?
Old Jan 23, 2008 | 09:43 PM
tru3_k177's Avatar
perth australia
in winter temp can get 10 to 25 deg
in summer it can go from 20 to 45 deg
Old Jan 24, 2008 | 02:01 AM
crvone's Avatar
5W-30, per my owner's manual. Have been using it since day1, in a temperature range not that much different from yours. I use Mobil1 and have been replacing oil &filter every 5,000 miles (that's ~8,000 Kilometers).Doesn't burn a drop of oil and never have had any oil leaks or related lubrication problems.
Old Jan 24, 2008 | 08:38 PM
tru3_k177's Avatar
its kinna hard to find 5w-30 here though... will it make a big difference if i use 10w-30
Old Jan 25, 2008 | 02:01 AM
You have to be using Celcius degrees:
10-25 C = 50-75 F
25-40 C = 70-110 F
If I am right, then 10w30 will be fine. You should use 5w-30 if the temperature gets to -5 C (<20 F)
Old Jan 25, 2008 | 08:30 AM
00AccordLX5spd's Avatar
Registered User
I have always used 10w30. I live in Mississippi where it rarely evergets below 0 Celcius or 32 F.
10w30should be just fine for you
Old Jan 25, 2008 | 08:33 AM
10-25 C = 50-77 F
25-40 C = 77-104 F
So that's correct, 10w-30 should be fine.
Once the enginegets to operating temperature, 5w-30 and 10w-30 are supposed to be the same. The "w" number is how the oil behaves at about 0°C & the number without the w is how the oil behaves at 100°C.
cliff
Apr 15, 2013 02:27 PM
Max Utility
May 19, 2011 12:32 AM
MiyashiMeism
Sep 5, 2010 02:12 PM
saanich
Sep 29, 2009 02:41 AM
