Oil Filters?
Old Jun 25, 2015 | 04:06 PM
Prospector's Avatar
Default Oil Filters?
Given that they both use Filtech media, is there any real difference between the Honda Filtech Oil Filter and the Bosch Filtech Oil Filter?
Old Jun 25, 2015 | 05:24 PM
shipo's Avatar
Very likely yes. Why? Just because Company A makes filters branded with both Company A and Company B does not in any way mean both filters are made to the same specifications.
Old Jun 25, 2015 | 06:01 PM
Prospector's Avatar
Thank you, Shipo
So, what would you recommend?
Old Jun 25, 2015 | 06:24 PM
shipo's Avatar
As with oil, for most applications I am an oil filter agnostic. For my Accord I use one of the Fram filters with the gritty band around it for better grip. Why? Because the location of the filter on the V6 motor isn't all that easy to reach and virtually impossible to reach with most filter wrenches.
The thing is, use good quality oil and filters, and the engine will far outlast the rest of the car.
Old Jun 26, 2015 | 01:23 AM
Prospector's Avatar
We are in agreement, Shipo... oil & filtration are vital for engine longevity
Years ago, I worked in a plant that produced filters (oil, water and air).. there is a great deal of difference in quality among filters depending upon the design and the type of and amount of media used.
My original question was if anyone knew, for sure, if there was a major difference between the Honda OEM Filtech and the Bosch Filtech... guess I'll do a search on the specs for each, then compare
Thanks again for responding
Old Jun 26, 2015 | 07:09 PM
I usually go with oem filters no matter the make. Usually the price difference is negligible. Unless there is a carbon copy of the filter for sale without the oem part number(like with volvo).
Old Jun 27, 2015 | 12:26 AM
UhOh's Avatar
Wow; with your background I hope you hang around the forum to contribute every so often!
Old Jun 27, 2015 | 12:51 AM
Prospector's Avatar
Thank you, UhOh
Just trying to learn something as I go along
Old Jun 27, 2015 | 10:05 AM
Better filtration paper may improve filter performance, but does it make any difference to engine wear? Not much is my guess (I don't know!) The big determinor in engine wear is changing the oil regularly at some reasonable interval.
There's a crowd over at bobistheoilguy forum that endlessly discuss merits of oil, filters, grease, and many other things.
Old Jun 27, 2015 | 10:37 AM
shipo's Avatar
Endlessly and with plenty of religious fervor; use a decent filter and all will be well with the engine, even after the rest of the car is useless.
mspk1111
Aug 7, 2009 11:53 PM
g1k
Aug 19, 2007 07:07 AM
rmistry7
Mar 24, 2007 01:09 PM
thunder_x
Oct 22, 2006 09:56 AM
19Accord97
Sep 12, 2006 09:52 AM
