Oil leak honda accord 1994 ex
Old May 29, 2012 | 03:39 AM
blubaustin's Avatar
Default Oil leak honda accord 1994 ex
Was just wondering if its common or not for there to be allot oil on the two wires above the oil pump on my car or not. If not what is it, and how do I replace it?
Old May 29, 2012 | 03:41 AM
94ex915's Avatar
Almost A Senior Member
Don't think there should be any oil coming out from anywhere lol.. How much is it leaking?
Old May 29, 2012 | 09:06 AM
blubaustin's Avatar
I didn't mean the oil pump...oops dont post I guess when tired. Its above the oil filter. And it always covered in oil, and it doesn't seem to be leaking all that much but enough to always keep the wires soaked in oil, I can post a picture tonight if need be. Unless of course I can find one somewhere on the net.
Old May 29, 2012 | 09:41 AM
crispin's Avatar
Sounds like your oil pressure sensor is leaking oil
Old May 29, 2012 | 12:43 PM
jerrym's Avatar
on my 97 Accord, had oil leaking down the side of the block, all over the oil filter. Thought the oil filter gasket was bad, so put a new filter on, still leaked though. Ended up starting the car up, getting underneath with a mirror, as the oil PS is kinda recessed back. Turns out the oil pressure switch was it. Got a new one from the dealer, easy to change out and think it was a 23mm socket. Did not have that size, but a 15/16 worked well if I recall.
Old May 29, 2012 | 07:54 PM
blubaustin's Avatar
Here's a picture, I tried circling it in red but it didn't work to well >_> The oil filter doesn't seem to ever be covered in oil but this wire thing does.
Old May 29, 2012 | 07:59 PM
crispin's Avatar
That line contains coolant not oil.
Are you sure it is oil that is leaking?
Old May 29, 2012 | 08:01 PM
crispin's Avatar
Edit - You have circled the Oil Pressure Switch.
It needs to be replaced.
Old May 29, 2012 | 08:05 PM
blubaustin's Avatar
Oh alright thanks, your edit didn't come in lol. Well I guess I'll be changing that out. Will a lot of oil come out when I change it or no? And I assume there isn't anywhere to buy one cheaper than $60 at autozone?
Old May 29, 2012 | 08:14 PM
The honda dealership one was ~$20. Sometimes the dealership does has better prices.
