oil not draining from the head
Old Apr 16, 2011 | 09:20 PM
cinobyte's Avatar
Default oil not draining from the head
I wanted to get some opinions on this problem. I am changing the valve cover gasket and all the spark plug seals next week. I wanted some suggestions on how to unclog the head without pushing all the gunk down further. Im afraid it will clog the lift tube or what ever its called if im not careful.
I considered running something through it for a day or two like seafoam then going to get an oil change.
The previous owner has probably been running the car with to much oil since he always dumped recommended amount during oil change even though a bunch of oil had not drained from the head.
Old Apr 16, 2011 | 10:23 PM
Suggest you leave hard, baked brown deposits alone. These are normal unless they are very thick. Large buildups can occur in some engines. I've not heard of Accords having this problem, but depending on how the car was driven I'm sure it's possible to clog an engine w/ deposits. A large buildup of coked oil could clog the oil return channels and possibly the oil pump intake screen.
Bob-is-the-oil-guy.com forum has extensive discussions of ways to clean an engine chemically and pitfalls of cleaning.
Old Apr 16, 2011 | 10:35 PM
cinobyte's Avatar
good info thanks
MyBrotha92LX
Oct 2, 2009 07:12 AM
RTM1216
Apr 12, 2009 12:54 PM
driver6198
Jan 2, 2009 11:19 PM
BallaxB09
Dec 12, 2007 06:21 PM
