Oil pan running on empty
Old Jun 4, 2013 | 11:37 AM
BusyDad99's Avatar
Originally Posted by shipo
If the engine is running well other than the light, I'd switch to 0W-40 oil and call it a day.
I strongly suspect bearing slop is your issue as those are typically the first to go when an oil starvation event occurs. That said, depending upon how much damage is in there, you could still drive it another fifty to one-hundred thousand miles with no problem, or suffer a bearing failure next week. Were I in your shoes I'd run heavier oil and then deal with any long term issues as they arose.
Well other than the shutter upon starting I believe there is noise now coming from the engine once warm. Would you care to estimate the cost of exploratory surgery and subsequent repairs if the Rod or mains have been effected. Would it be worth it on a car of this age? It has approximately 135,000 miles but brakes are needed soon and CV boots are busted. Thanks for your input
Old Jun 4, 2013 | 12:15 PM
shipo's Avatar
I could estimate, but I'd be wrong; probably very wrong.
If there really is noise coming from the motor, then I'd be inclined to go buy a good low-mileage motor from a bone yard and just do a complete engine swap. The price of a used motor varies, but I've heard any number of folks posting that they'd found a good motor for under $500, sometimes well under.
At this point what you have to do is to weigh the cost of repairs against what you can get for your car with a sick motor and then apply that to the purchase of a replacement vehicle.
FWIW, I was faced with a similar situation a few years ago; I had a car well into its second hundred thousand miles that lost its transmission. The car was otherwise sound and was essentially worthless without a transmission, however, the flip side is that I needed a car regardless, and to buy something comparable would have cost easily double the cost of the new transmission. I bet on the new transmission; turned out to be a good bet, I drove it another 70,000 miles (with very little extra unscheduled maintenance) and then got decent value as a trade-in when time came for a new car.
Old Jun 5, 2013 | 09:09 PM
Silver6gen's Avatar
oil pump is burnt and not functioning properly. Could have also done everything everyone above has said.
Get an oil pressure gauge and hook it to the sender unit see what presure you develop. should be 25psi after warm at idle. on a cold start-up should be around 75-100psi
Old Jun 5, 2013 | 10:18 PM
How much oil did you add when the light first turned on?
ccookie66
Apr 12, 2019 04:43 PM
kanchi647
Aug 11, 2013 09:58 PM
Kerri
May 23, 2013 11:57 AM
frost506
Jan 16, 2012 07:21 PM
greg9442
Oct 15, 2009 10:37 AM
