Oil Pressure Indicator Light Issue
Old Feb 19, 2019 | 05:09 PM
hmr's Avatar
hmr
Default Oil Pressure Indicator Light Issue
I own a 2000 Honda Accord EX sedan, A/T, 4 cylinder. Recently my oil pressure indicator light started flickering when I would come to a stop. My mechanic diagnosed the problem as a bad oil pressure switch and replaced it. The oil pump checked out fine. Road tested the car and the oil pressure indicator light still flickered as described above. He cleaned the connection and road tested again. No change. Still flickering at a stop. The mechanic says that the only remedy left is to try a thicker oil. Do you agree ? Thanks much for any input.
Old Feb 19, 2019 | 05:56 PM
UhOh's Avatar
No.
From long ago I tried to beef up the oil pressure on an old Triumph TR-3 (which had actual oil pressure gauge)
by going to higher viscosity oil - did not work. I kept driving it with low oil pressure and it continued to work.
Perspective: you've an old car, like mine. As long as you have enough oil volume, by the dipstick, and an operating oil pump
you won't have a problem that's worth addressing vs. the value of your car. So:
1) get some black electricians' tape and cover up the warning light, since it understandably bothers you
2) check and top off the oil every 1000 miles, or whatever interval you choose.
Drive it and don't sweat it. (Can always join AAA)
Old Feb 19, 2019 | 08:16 PM
shipo's Avatar
Sounds like a loose bottom end. Keep oil in it and drive'er till she drops. I had a car many years ago with loose bearings and drove it nearly 100,000 miles with a flickering oil pressure light when at idle.
Old Feb 19, 2019 | 08:27 PM
Did your mechanic test the oil pressure with the switch removed? If the pressure is good, then you have an electrical issue somewhere between the oil pressure switch and the gauge cluster.
Old Feb 20, 2019 | 03:30 PM
The Toecutter's Avatar
Originally Posted by PAhonda
Did you mechanic test the oil pressure with the switch removed? If the pressure is good, then you have an electrical issue somewhere between the oil pressure switch and the gauge cluster.
That was kind of my thought as well, or a pressure switch set to come on at the wrong oil pressure (I've had that happen before).
Old Feb 24, 2019 | 10:26 PM
ticktock's Avatar
Hi hmr,
Three years ago, my 92 Accord had the same thing: flickering oil pressure when stop. If shifted to N, the flickering stopped. If not after a minute or two, the flickering became solid on. I replaced the oil pressure with no luck. Brought it to the shop and the mechanic said it was internal leak due to some bad gaskets. He replaced them and the flickering was gone.
Ted
Old Feb 28, 2019 | 04:44 PM
hmr's Avatar
hmr
Originally Posted by UhOh
No.
The mechanic wanted to try a thicker engine oil. So, he went with conventional oil 10W/30. No engine oil light flicker at idle around town and short drives. BUT, on a longer, freeway speeds, trip the light will eventually start flickering at idle. I guess that the engine clearances in this older car aren't as tight as with a newer car. So, I guess nothing to do but ignore it as long as the light only flickers as I have described here ?
Old Feb 28, 2019 | 05:20 PM
My wife's 00 Accord AT has been using 10W30 ever since we've had it (Nov 2015), and no issues at 239K miles. In my 99 Accord w/5 speed (238K miles), I run 10W40 in it, as I use that weight in my Toyota, my Chevy van, and my VWs. No issues in any of them, but I change the oil every 3K miles (uses dino oil).
Old Feb 28, 2019 | 05:46 PM
hmr's Avatar
hmr
I took a trip today. Approx. 24 miles to my destination, then parked the car for approx. 1 1/2 hours, then another approx. 24 miles to return home. Mostly freeway driving. On the way back home the light started flickering at a couple of stop signs. When I shift into neutral while at the stop sign. I noticed that the RPMs drop slightly as I shift to neutral and the light flickers.
Old Feb 28, 2019 | 06:12 PM
shipo's Avatar
What you describe is totally expected for your engine.
