Oil Pressure Indicator Light Issue
Old Feb 28, 2019 | 06:39 PM
Sometimes it's due to low RPM especially when you first stop.
Try going through the "base-idle" setting & the process of forcing the PCM to "re-learn" the idle.
https://www.hondaaccordforum.com/for...e-speed-38734/
Old Jul 12, 2024 | 12:22 PM
alpaulson23's Avatar
Originally Posted by hmr
The mechanic wanted to try a thicker engine oil. So, he went with conventional oil 10W/30. No engine oil light flicker at idle around town and short drives. BUT, on a longer, freeway speeds, trip the light will eventually start flickering at idle. I guess that the engine clearances in this older car aren't as tight as with a newer car. So, I guess nothing to do but ignore it as long as the light only flickers as I have described here ?
I have been having this same issue recently and it’s really been throwing me off. You say the engine clearances aren’t as tight? Which specific clearances are those?
Old Jul 12, 2024 | 12:43 PM
kris_loehr's Avatar
Please have the oil pressure checked. All thicker oil will do it put a band aid on the issue. If you have low oil pressure it is going to be a bad oil pump or worn out rod or main bearing or both. Oil pressure lowers when the engine warms up. I have seen people put really thick oil in a car with low oil pressure to trade it in at the dealership.
hmr
Apr 11, 2019 04:54 PM
blackhonda1991
May 8, 2012 10:40 AM
Adler
Jul 22, 2011 05:43 PM
erikhans
May 6, 2009 09:33 PM
saad180
Jun 11, 2007 02:45 PM
