oil in spark plug tubes
Got oil in my spark plug tubes on #2 plug only. I can see it pooled in the bottom when I look down there and when i take out the plug. I had the tube seals replaced abour 2 months ago when i had my valves adjusted. So, should I assume its now the lower rocker arm seals that I should try next to solve this?
it's either the lowers or an improperly installed upper seal. I'd just buy a set (uppers and lowers) and take it apart, if you find that there is a problem with that seal then I'd just do the uppers, if it looks fine I'd tear into the lower seals.... Either way you'll have to pull the valve cover to know so just get the parts and pull the cover....
Just my $0.02 anyway
Probably the little dinky seals under the rockers assy. are rock hard and seeping
As you are looking down the spark plug tube you can see the seam/crack where they are.
go to our DIY section and replace the lower seals,, there is a step by step write up
get the lower rocker arm seals from the dealer , you will need 4 ..if they just replaced the upper seals i am to assume that they are still good and reusable
hey i replaced my valve cover seal and the spark plug hole seals.. and i still find oil on my spark plug wires..
those spoken as #19 on that pic.. i replaced those and still find oil down there.. im worried..
