oil in spark plug tubes
Old Jan 4, 2007 | 11:24 PM
Default RE: oil in spark plug tubes
#19 ARE the lower tube seals.
But did you have the properbolt tightening sequence & torque for those cam caps? How did the O-ring groove clean up? Any scratches or crud to prevent those from making a good seal?
Old Jan 5, 2007 | 01:24 AM
ArcticHonda's Avatar
Could a failure of the valve cover seals and the rocker arm seals both lead to oil in the tube. Or could one just result in oil on the electrode but not in the tube? Just trying to diagnose.
Old Jan 5, 2007 | 01:50 AM
deserthonda's Avatar
ORIGINAL: ArcticHonda
oil in the plug electrode is a different issue could be leaking valve seals and or worn piston rings
Old Jan 5, 2007 | 11:01 AM
The question is how the oil got on the electrodes.
Leaking VC gasket or lower tube seals only gets oil on the outside of the plug. But sometimes there's enough oil that it gets onto the electrodes just as you're unscrewing the plug.
Oil that'sactually inside the combustion chamber can't come from those seals. Gotta be rings or valves...
Old Jan 5, 2007 | 12:28 PM
So in other words its good that the oil is in the spark plug tube and not on the electrode- thus indicating bad seals and not bad rings or valves, right?
Old Jan 5, 2007 | 04:59 PM
sir_nasty's Avatar
You got it! If it was on the electrod eventually you'd start seeing blue smoke blowing out the back and that's a bad thing...
bigdawg74
May 28, 2013 08:48 PM
bigdawg74
Jul 30, 2011 06:50 PM
19Accord97
Jul 28, 2008 10:56 AM
patcal
Nov 27, 2006 11:33 AM
deserthonda
Apr 16, 2006 04:22 AM
