Oil on spark plug wires?
hmm, is this normal, because mine has this a little bit, butpower is still good on car and there is no difference, my freinds 93 EX is the same way as mine, so is this normal or are any seals worn? but what are the odds that this happens on 3 of the cars that i know of?
thanks
thanks
If you search the site, you will see it happens a lot. Oil shouldn't get on the spark plug wires. The seals on the valve cover get brittle and start leaking. There is a post in the DIY section about this.
as long as it's not a lot of oil you can leave it if your short on $$. if it's a lot of oil it can cause an engine fire. the oil saturates the plug wire boots and causes spark to ground to the head. i've had two engine fires from that so far, it's rare...but happens.
ORIGINAL: HondatechAV6
you'll need the vc gasket, spark plug tube upper seals and spark plug tube lower seals, and hondabond.
For those of us who can't get/afford hondabond, what is a suitable alternative?
