Oil on spark plug wires?
Old Dec 30, 2007 | 03:40 PM
4thgenaccord88's Avatar
Default Oil on spark plug wires?
hmm, is this normal, because mine has this a little bit, butpower is still good on car and there is no difference, my freinds 93 EX is the same way as mine, so is this normal or are any seals worn? but what are the odds that this happens on 3 of the cars that i know of?
thanks
Old Dec 30, 2007 | 04:32 PM
Default RE: Oil on spark plug wires?
If you search the site, you will see it happens a lot. Oil shouldn't get on the spark plug wires. The seals on the valve cover get brittle and start leaking. There is a post in the DIY section about this.
Old Dec 30, 2007 | 10:07 PM
HondatechAV6's Avatar
as long as it's not a lot of oil you can leave it if your short on $$. if it's a lot of oil it can cause an engine fire. the oil saturates the plug wire boots and causes spark to ground to the head. i've had two engine fires from that so far, it's rare...but happens.
Old Dec 30, 2007 | 11:01 PM
eek, i gotta fix that, so its just the valve cover gasket?
Old Dec 30, 2007 | 11:36 PM
afghandragon45's Avatar
yeah, pretty much. my accord had the same problem and my mechanic changed the valve cover gasket and the rocker arm seal or something and it seems fine now
Old Dec 31, 2007 | 06:35 PM
you'll need the vc gasket, spark plug tube upper seals and spark plug tube lower seals, and hondabond.
Old Jan 4, 2008 | 02:40 PM
Accord_Ras's Avatar
ORIGINAL: HondatechAV6
For those of us who can't get/afford hondabond, what is a suitable alternative?
Old Jan 4, 2008 | 02:46 PM
oma93's Avatar
I used Permatex non-hardening gasket sealer (on advice from some folks here) and it worked fine. It's not the same as the RTV silicone.
Old Jan 4, 2008 | 03:03 PM
sir_nasty's Avatar
I haven't done a ton of honda gaskets but I've always used High Temp RTV on my other vehicles when I needed it....
Old Jan 4, 2008 | 03:04 PM
I've been told that Permatex GREY gasket goop is about the same. I've used it & it worked.
