Sponsored by:
Sponsored by:
Old Faithful needs a New Timing Belt
Old 03-15-2010, 04:20 PM
audiocr381ve's Avatar
Default Old Faithful needs a New Timing Belt
Hi guys, first of all, pleasure to be a new member of the forum.
I'm getting the timing belt done on my 1996 Accord LX, and I have a few questions about parts, and where to shop. I won't be doing the install myself, but I do need to buy ALL necessary parts for my mechanic.
1. When changing out the timing belt, I understand a few things get done like replacing the water pump. I heard a few other things need to be done too but I don't know the exact technical terms, I believe it's along the lines of crank shaft, or cam seals (don't know if that even makes sense). Anyway, that's my first question, what parts do I need to buy for my mechanic when performing a timing belt change?
2. Is it best to buy online? If so, what are the best online stores to buy these specific parts from?
All other advice on purchasing parts or anything would be greatly appreciated!
Respectfully,
Shane
Old 03-15-2010, 11:39 PM
hondadude's Avatar
T-belt, counterbalance Belt, Cam seal, Crank seal, Front counterbalance shaft seal,
Front counterbalance shaft seal RETAINER [if not already installed]
Also change whats called the 'oil pump seal'.
Water pump, one gallon of Fresh Coolant and it's a great time to put in a new T-stat because all the coolant will be out, and a new T-stat is really cheap insurance.
Here's a web address;
www. hondaautomotiveparts .com
Last edited by hondadude; 03-15-2010 at 11:52 PM. Reason: link // unknown if they are a sponser
Old 03-16-2010, 10:48 AM
00AccordLX5spd's Avatar
Registered User
Don't forget the water pump (I see you mentioned but Hondadude did not.) Some people like to go ahead & replace the tensioners too. I didn't have mine done at 104k, but I will do them next time at 210k.
Genuine Honda parts for this. The site hondadude linked is the cheapest I have found on the net (but I haven't looked in a while.)
Old 03-16-2010, 10:59 AM
hondadude's Avatar
Huh?
Please have your eyeglasses prescription checked.
Old 03-16-2010, 11:01 AM
Registered User
Woops... I did miss it. My bad
Old 03-17-2010, 02:29 PM
Default Thanks guys.
Thanks for the info guys.
One last question, what is the quantity (besides the obvious ones, 1 timing belt, 1 water pump) of each item? Gonna order right now.
fixinmyself
06-18-2015 07:04 PM
ozofjakes
01-04-2013 09:09 PM
jrcastro
04-21-2008 10:35 AM
Tony1M
04-01-2007 05:42 PM
kturnerga
09-25-2006 05:13 PM
Quick Reply: Old Faithful needs a New Timing Belt
