One Moody Car
Old Dec 18, 2007 | 07:26 AM
  #21
JohnL's Avatar
Default RE: One Moody Car
ORIGINAL: 05hondaman
Thanks for all that info, JohnL.
I would tend to think of it more as speculation than hard info..
Well, the crazy thing ran pretty good this afternoon. We've got warmer temps, around 54 degress or so. It seemed to be more it's old self again. As for the injectors, I run a cleaner through there about every 3k miles or so called Sea Foam. Plus, I use a detergent gas. I still would like them to check it over, be sure something like that isn't wrong, but it sure did better today.
Warmer weather, better fuel atomisation? Sounds unlikely that general accumulated grunge is to blame. I was tending to think more along the lines of a small piece of something (grit, errant manufacturing swarf?) partially blocking an injector.
Have you had the fuel filter flow rate checked? Another unlikely, but I'm shooting in the dark a bit!
Maybe things are leveling off. I've seen it go through moody times before and finally get zippy again. But as I say, I want them to check it out really good to be sure.
Even if it seems to fix itself, it will prey on your mind, never know when next time will be!
I hope they think the SRI will work. I'd like nothing more than to give it a little soup up!
I'd be more inclined toward a CAI (cold air intake) than a SRI. The trouble with SRIs is that they suck hot air from inside the engine bay, and hot air definitely costs power. I believe the rule of thumb is for every additional 10°C induction temp you lose 1% power, so if the engine bay were say 70°C and ambient were say 20°C you'd be losing around 5% power, for no good reason.
Ignoring any temp considerations, an SRI may or may not make more power, may make less power, or may make more power somewhere in the rev range but less somewhere else in the range. It would depend on whether or not your engine was sensitive to induction tract lengths or not, and if so how so, and how much so.
The rule of thumb is that shortening the induction tract will tend to gain top end power, but lose bottom end. The opposite is the case if lengthening the tract. The length of the manifold / ports (tube from valve heads to the larger cavity of the plenum) is probably the most important part in this respect, a change in this length is likely to have a pronounced affect. But, the overall length of the whole system up to at least the throttle body will probably be significant.
I don't know what sort of SRI you might use, but if it's the kind that eliminates the plenum andreplaces it with seperateinduction tubes and throttle bodies for each cylinder then I doubt it would workwell at lower rpm. A CAI will use the existing plenum and throttle body (and possibly filter), and I expect would have little affect on the 'tuned length' of the induction system...
Are you an induction roar junkie? An SRI is likely to be quite loud, OK if you like that sort of thing (I just love the sound of a set of unsilenced Weber DCOEs on full noise!), but it can get wearing after a while. An unslilenced induction can make as much or more noise than a loud exhaust sytem, be warned!
Assuming an SRI won't cost you power but in fact gain you some, an SRI hooked up to a CAI might be the best of both worlds, still noisy though, perhaps less so than just an SRI (?).
Old Dec 18, 2007 | 09:08 AM
  #22
05hondaman's Avatar
Again, thanks for all the info. I guess I'll skip the add ons. Sounds like it can hurt more than it helps, and I never had any of that work done, so I don't know where you got that information. Ain't me.
Old Dec 18, 2007 | 10:15 AM
  #23
05hondaman's Avatar
Thinking back, they did replace some kind of module that was causing a roar to come through the sound system, that noise-cancelling stuff on this type car, but they never had to tear out the transmission to do it. It didn't take over an hour to fix.
Old Dec 18, 2007 | 12:56 PM
  #24
sir_nasty's Avatar
that's odd that hondatechav would find those repairs but you're not aware of what they are, the car only had like 178 miles when you bought it and you're the first owner so I wonder where those notes came from...
On a side note I don't think the SRI is going to hurt anything except it can add some noise (that nice low grumble when you romp on the throttle), I'd probably just wait and see what the dealer says on it...
Old Dec 18, 2007 | 03:34 PM
  #25
JohnL's Avatar
ORIGINAL: sir_nasty
Due to affects on induction tract harmonics, an SRI may well not hurt power at all, it may affect power to an unoticable degree (+ or -),it may to a noticable degree, or it might be noticably beneficial, hard to say how long the string is until you've measured it. Most SRIs I've seen draw air from inside the engine bay, which isn't a 'good thing'. Some don't even have filters installed, very bad!
Hot induction air is well recognised to rob at least some power in just about any application, why racing cars almost universally use non restrictive cold air intakes. Even the car manufacturers seem to have resognised this, I can't recall seeing a newer car that draws air from inside the engine bay for quite soome time. This might not be done for any power reasons, may be more of a fuel consumption issue for them(?), some of the factory CAIs are very restrictive (not good for power).
If you want some increased induction music, an aftermarketCAI will almost certainly be louder than the standard induction piping etc. Keep in mind too that many standard induction tracts are quite restrictive before the throttle body, often only at one point, but that's all it takes to strangle the engine, at least to some degree.
Old Dec 18, 2007 | 06:50 PM
  #26
HondatechAV6's Avatar
yeah, the second warranty repair was the active noise control unit was replaced. the first repair - 07/25/07 07/24/07 63143 12,132 118099 03217 1A810-RCJ-003 - shows the stator position sensor was replaced. trans had to be removed for that.
#12 - it's goes around the crank.
Old Dec 19, 2007 | 07:16 PM
  #27
05hondaman's Avatar
Hmm, that's the fastest transmission tear down and put back I'd ever heard of! They sure didn't mention doing that, to me.
Today was about the same old same olds. Ran great before warm up, then just fair after about an hour or so city driving. Where I'm noticing it most is when a car ahead has turned off, I'm doing around 25mph, then I want to accelerate. It will feel like it's smothering a bit for more gas or air, whichever. Not a severe drop, but to me, adrop, more than it has had. I mean it ticks me to have a hard time keeping up with a granny in her Buick unless I floor it, then I get 5krpm andit will catch up. You kinda want more from a 255 V-6.[:@]
Old Dec 19, 2007 | 07:27 PM
  #28
05hondaman's Avatar
I just emailed the foreman something else that has haunted me about that car. When I was cleaning it out way back, I found a piece of paper in it with another person's name on it as if it had had a previous owner! We bought it new, and with that low a mileage, I don't know why that paper would've been in the lockbox or wherever I found it. Wish I could find that paper now.
Old Dec 19, 2007 | 07:46 PM
  #29
well, do you have the reciept for that visit on 7/24 or 7/25?
Old Dec 20, 2007 | 08:01 AM
  #30
05hondaman's Avatar
No, but I do have THIS from my shop foreman about how people can know so much about my car.
WOW, THAT SEEMS REALLY WEIRD…MAKES ME WONDER IF THERE ARE ANY VIOLATIONS OF THE PRIVACY ACT WITH THIS GUY AND HOW HE GETS HIS INFORMATION. NONE THE LESS, DO YOU REMEMBER HOW MANY MILES WERE ON IT WHEN YOU BOUGHT IT? I HAVE HISTORY STARTING AT 125 MILES AND SEE NO WORK RESEMBLING THE IMA POSITION SENSOR.
BUTCH
