Overheating at idle
Old Jan 8, 2014 | 05:08 PM
flyin's Avatar
Im having the same issue with a 1990 honda accord lx . i jumped the thermostat sensor with key on and the fan did not come on , but i jumped the cooling fan relay in the cluster box and the fan turned on . im reading in alot of post it might be a Fan Timer module ... any thoughts ?
Old Jan 8, 2014 | 06:18 PM
kris_loehr's Avatar
On my 1995 Accord I was losing coolant which never left any signs of leakage and turned out it was the heater hose on the back of the engine below the leaking valve cover which ballooned the hose. It passed a pressure check up until the day the hose completely failed.
Old Jan 8, 2014 | 07:57 PM
john74's Avatar
blocked line, thermostat, or water pump..
Old Jan 9, 2014 | 04:22 PM
kayweb's Avatar
The heater hose sounds like a likely culprit. I'll check that when I replace my pressure sender.
Old Jan 9, 2014 | 04:46 PM
Also, install the a/c condenser fan, because you need both to properly cool the radiator.
Old Jan 10, 2014 | 04:14 AM
holmesnmanny's Avatar
If you have a film that appears on the inside of your windshield with the windows up it could be a bad heater core leaking coolant.
Old Jan 10, 2014 | 05:07 AM
  #17
kayweb's Avatar
Yep, definitely fogs up all the time, but it doesn't smell like coolant. Doesn't smell great though.
troc88
Apr 21, 2011 06:14 PM
Krmnnghia
Aug 26, 2009 07:24 PM
d_10
Jun 27, 2007 10:01 PM
PIGGEBANK
Oct 1, 2006 08:18 PM
Joshporsche
Jun 14, 2006 10:07 PM
