Overheating issue, again..
Old May 31, 2012 | 05:49 PM
  #41
crispin's Avatar
Coolant temp normal range for all cars is apx 180-210 degrees
Old May 31, 2012 | 05:59 PM
  #42
Originally Posted by nrmskate
What is the normal operating temp range of a 96 accord 2.2L?
Normal operating temperature is 89 - 90 degrees Celcius (approx. 192 - 194 degrees F). The thermostat should be opened at normal operating temp. The range is still normal somewhat above that (above approx. 89 degrees C or ~ 209 degrees F) before it actually overheats. See this link which shows how it also normally looks on the gauge:
Overheating Troubleshoot for Honda's Cooling System
The Honda OEM thermostat on your car should start opening at 169 - 176 degrees F, and be fully opened at 194 degree F.
Old May 31, 2012 | 06:47 PM
  #43
200 f
Old May 31, 2012 | 08:05 PM
  #44
nrmskate's Avatar
I have an infrared thermostat and the fans start running at 210f and shut off at 190f. Is this about normal? I'm just thinking that's it's my gauge that is bad, at 210f, my gauge needle is at 3/4 of the way on the gauge, is this about normal?
Old May 31, 2012 | 10:22 PM
  #45
I'd say OK. Some people say the fans come on earlier (based on the gauge), but the gauge isn't always accurate from one car to another.
Old May 31, 2012 | 10:32 PM
  #46
Based on the service manual , the Honda OEM thermo-switch A normally switches on at/or between 194 to 205 degrees F, then should switch off 36 - 45 degrees lower than when it switched on. If your normal operating temp. is 210 degrees F, you appear to be running on the high side of normal.
Honda use to have a test similar to this to check whether the radiator was the problem (I do see that you listed the radiator was replaced though). Get the car up to normal operating temperature, with your infrared temp. sensor, compare the temperature difference between the upper and lower radiator hoses. If there is more than a 15 degree F difference, the radiator flow is okay, if less than 15 degrees F, then the radiator flow is not okay.
Old Jun 1, 2012 | 04:25 PM
  #47
nrmskate's Avatar
I did that test redbull and the temps are within 2f of eachother.
Old Jun 1, 2012 | 04:52 PM
  #48
I looked at the notes again, and the check is done under the same condition when overheating occurred. The attached are older instructions before the advent of now commonly available infrared temp. sensors where they used thermocouples.
First90AccordMan
Feb 25, 2012 08:28 AM
bigb609
Dec 27, 2011 07:18 PM
kennilope
Aug 9, 2007 10:11 PM
Jul 24, 2006 03:55 AM
Jun 2, 2006 02:24 AM
