oversized radiator
Old Dec 23, 2011 | 07:06 PM
Jason94accord's Avatar
Default oversized radiator
I have an aluminum oversized radiator (Mishimoto as shown on the picture) with 19 lbs on the cap. My problem is my coolant fan isnt turning on but when i turn my ac on the ac fan works. I was told i should drop down to 14-16 lbs but i wanted to ask you guys since u guys are the gurus when it comes to accords. Im not overheating but ive never drove over an hour straight in my car yet. but when i do drive for a while i check my radiator and its very hot. Please help and thanks!
Old Dec 23, 2011 | 08:04 PM
UhOh's Avatar
Well, my fan doesn't come on when moving on real road.
But when car's warm, and I drive up a hill in 1st gear (rough dirt road) it does come on.
I don't really see a problem w/ your car other than your concern and your trying to do the right thing. But your having data would help I bet, so
next time you (?) order from Harbor Freight Tools add $15 and get their cheapest infrared temp sensor. (I've one)
You can then measure your radiator temp instantly by pointing it at it, while still inches away.
Peace of mind for you, imo.
Old Dec 23, 2011 | 08:49 PM
i didnt order this from harbor freight tools. i don't think my radiator getting extremely hot to the point where you can only tap it is a good thing. but im not a mechanic thats y im on here. i was thinking my radiator was too big or something ive seen a couple picturess of other engine on here and havent seen a radiator my size yet.
Old Dec 24, 2011 | 09:02 AM
Thermo A (on the t-stat-green connector) will make the fans come on when the engine is on. From the factory it does this ~196*....so if it never gets to that point then they won't come on, testing would be required.
Old Dec 24, 2011 | 01:18 PM
thnx bro i will try that today if i get the time and $
Old Dec 24, 2011 | 01:30 PM
If the temp gauge is not getting to half or higher then I wouldn't worry too much. The larger rad and current cool temps might be keeping it from getting to that point.
Old Dec 24, 2011 | 03:13 PM
UhOh's Avatar
avoiding confusion via PM messages between us ... and helping others out, maybe.
This is the inexpensive infra red temp sensor from Harbor Freight Tools (.com?) that I referred to above.
I checked its readout accuracy and it is stinking right on! Nice surprise to me.
BigRoach
Jun 3, 2013 01:54 PM
Novaknowledgenow
May 30, 2013 08:58 PM
hmr
Mar 28, 2012 10:49 PM
erikhans
Apr 14, 2009 07:35 PM
Oct 5, 2005 08:49 PM
