Oxygen Sensor Fault
Old Oct 29, 2012 | 07:03 PM
Jethead102's Avatar
Default Oxygen Sensor Fault
I am having trouble with my upstream O2 sensor, I unplugged but did not remove it several days ago and the CEL came on. I cleared it several times, but it continues to come back. I have checked that it is plugged in nice and snug. The sensor was working fine before. Any ideas as to what happened? I'd rather not splurge for a new sensor if I don't need to. 02 Accord EX F32A1 134k
Old Oct 29, 2012 | 07:09 PM
What code was presented?
Old Oct 29, 2012 | 08:04 PM
Jethead102's Avatar
P0135
Old Oct 30, 2012 | 05:56 AM
PO135 is a fault in heater circuit of the A/F sensor. This usually means the heating element has failed. Disconnect and check resistance of heating element (same color wires usually). A wiring diagram is necessary to find the heating element wires otherwise.
Good resistance would be perhaps 10-20 ohms. If open or dead short, a new A/F sensor is necessary.
Old Oct 30, 2012 | 09:41 AM
Be sure to also check the #6 fuse in the under dash fuse panel.
Old Oct 30, 2012 | 09:52 AM
Jethead102's Avatar
Thanks! I'll check it out when I get off work.
Old Oct 31, 2012 | 02:58 PM
Jethead102's Avatar
I checked the fuse, which was ok. The heater circuit is bad, so I'm guessing that I need a new sensor. Is it ok to put a sensor labeled downstream in the upstream position? I'm looking at a price difference of over 20 bucks, and I wouldn't think with a universal sensor that it would make a big difference.
Old Oct 31, 2012 | 07:41 PM
You have an Air/Fuel Sensor, not a O2 sensor. Downstream sensor is an O2 sensor, so swap won't work.
Suggest checking ebay, amazon, and rockauto for best deal on a denso A/F sensor.
3dw1n
Jan 14, 2015 01:53 AM
jacksta
Jun 25, 2010 04:19 PM
dmost30
Sep 8, 2008 12:42 AM
dmost30
93AccordLX
Nov 21, 2005 09:22 AM
