P0135 - 2002 Accord SE
Old Mar 23, 2011 | 09:30 AM
Rhodes_TL's Avatar
Default P0135 - 2002 Accord SE
Error Code from OBD II:
P0135
Oxygen Sensor Heater
Bank 1 Sensor 1
Is this the O2 sensor that is up front visible with the hood open, or is the one from under the car?
Thanks
Old Mar 23, 2011 | 11:05 AM
4-cyl engine??
Yes, it's the one in front. Unplug it & find the 2 same-color wires on the sensor side of the plug. Measure resistance between those. For a non-ULEV engine that should be 10 to 40 ohms. A bad sensor will usually be open-circuit.
For a ULEV engine, the correct resistance might be different but I don't know what it should be.
If that measurement is OK, then you'll have to troubleshoot wiring problems in the car.
slickgeek
Feb 24, 2014 02:48 PM
dogmarcopolo
Jan 25, 2013 07:22 AM
aswflyer
Oct 1, 2012 12:21 PM
jpaccord98
Jan 22, 2012 07:48 PM
efster420
Feb 13, 2010 01:04 PM
